[GRASS-dev] Default content for the "answer" to G_OPT_F_INPUT
Nikos Alexandris
nik at nikosalexandris.net
Tue Apr 17 07:32:54 PDT 2018
Le Mardi 17 avril 2018, Markus Metz a écrit :
> On Tue, Apr 17, 2018 at 4:21 PM, Nikos Alexandris <nik at nikosalexandris.net>
> wrote:
> > * Moritz Lennert <mlennert at club.worldonline.be> [2018-04-17 15:56:10
> +0200]:
> >> On 17/04/18 15:31, Nikos Alexandris wrote:
> >>> Dear developers,
> >>> is there a way to set a string as the content of a default "answer" for
> >>> the G_OPT_F_INPUT option? I am trying to identify potential cases in the
> >>> grass-addons repository, but I am not sure I have seen something
> related.
> >>> The G_OPT_F_INPUT offers a field to enter a filename. The default
> >>> "answer", for the parser, will be the name of the file.
> >>> In addition, a field to "enter values directly" is created. The
> >>> description of this field is: "Enter file content directly instead of
> >>> specifying a file. Temporary file will be automatically created."
> >>> Can this field be filled with a pre-defined content?
> >>> The use case is to expose, to the user, a pre-defined set of
> >>> reclassification rules. These will help a beginner to get started,
> >>> understand easier and modify rules as he sees fit.
> >> Use the 'answer' parameter:
> >> #% answer : myfilename
> >> Moritz
> > It works: it loads the content of an external file. Are we forced to use
> > external files in such a case? Which means an extra file has to be
> > shipped with the source code.
> > Can we not use an in-script hardcoded string for example?
> Be aware that you can't use a hardcoded full path, because depending on the
> installation/user/os, that path may or may not exist. If you use a relative
> path, that path is relative to the current working directory which is of
> course not constant between sessions/installation/user/os. I'm afraid a
> default answer to G_OPT_F_INPUT will cause a lot of trouble.
> my2c
> Markus M
Ciao Markus.
Yet my intention was/is to use a hardcoded string of rules. Not a path to a file.
It appears the only option is to document, the rules, and suggest a copy and paste in to the corresponding field.
Can the parser be extended in this regard with yet another option? Perhaps I missed some existing option (?).
Thank you Markus, Nikos
