[GRASS-dev] [GRASS GIS] #3554: r.slope.aspect: add flag/functionality to not shrink
Steven Pawley
dr.stevenpawley at gmail.com
Sun Apr 29 22:31:08 PDT 2018
Thanks Markus for the update to r.slope.aspect, and for the additional info.
I just updated the mapcalc part of r.valley.bottom (72655)to deal with null
values as part of the mapcalc expression. I used the strategy of firstly
attempting to replace null pixels in the neighbourhood with their opposite
(i.e. mirroring), and if that also results in a null value (i.e. in
corners) then the value of the centre pixel is used.
Steve
On Sun, Apr 29, 2018 at 8:30 AM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Sun, Apr 29, 2018 at 7:36 AM, Steven Pawley <dr.stevenpawley at gmail.com>
> wrote:
> > Handling of nodata values at raster borders for modules which involve
> focal functions would be handy to have for several GRASS GIS modules, not
> just for r.slope.aspect. IMHO r.mapcalc, r.texture, and r.resamp.interp (if
> using bilinear or cubic resampling) would also benefit from this option
> (perhaps other tools as well).
> r.texture already has the -n flag: Allow NULL cells in a moving window
> r.slope.aspect has a new -e flag: Compute output at edges and near NULL
> values (same like gdaldem -compute_edges)
> r.mapcalc has the isnull() function and the special operators "&&&" and
> "|||" handling NULL values
> r.resamp.interp needs to be done for bilinear, bicubic, lanczos,
> implementation could be relatively easy in the raster library functions
> Markus M
> > Although some users may be concerned that filling nodata values at
> raster borders can create edge effects, in most cases the common approaches
> (such as mirroring, reflecting or wrapping) leave little in the way of an
> obvious edge effect, and also satisfy what I think are most user's
> expectations that the output raster will have the same dimensions as the
> input.
> > Although a similar effect can be achieved by growing the input raster
> first, this can be inconvenient when used as part of a complex set of focal
> function operations. An example is that I have just completed working on an
> updated r.valley.bottom module, which required multiple r.grow operations
> as the algorithm repeatedly generalizes the input DEM and calculate
> flatness and lowness using r.slope.aspect and r.mapcalc focal functions. It
> also appears that most other tools, including SAGA-GIS, scipy (image
> filters), and gdaldem provide a method to handle raster borders.
> >> Reporter: hellik | Owner: grass-dev@…
> >> Type: enhancement | Status: new
> >> Priority: normal | Milestone: 8.0.0
> >> Component: Raster | Version: svn-trunk
> >> Keywords: | CPU: All
> >> Platform: All |
> >> at the moment, the result maps of r.slope.aspect, e.g. slope etc, are
> >> shrinked by 1 pixel.
> >> adding a flag/functionality to not shrink the result maps e.g. by
> adding
> >> the same value as the -1 off pixel, some interpolations or similar as
> an
> >> enhancement.
> >> Ticket URL: <https://trac.osgeo.org/grass/ticket/3554>
> >> GRASS GIS <https://grass.osgeo.org>
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180429/85dc2253/attachment.html>
