[GRASS-dev] Help text for r.stats
Nikos Alexandris nik at nikosalexandris.net
Wed Aug 1 02:54:28 PDT 2018
Ciao Vero,
I had a look. I am not yet that familiar with the "UI" construction from
C source code, so I am not sure where to dig for this (comment: with
Python it's easy).
As noted, and as you likely have observed,
the 'html' manual mentions all options. They are only missing in
the command line help text.
The same is valid for `r.univar`, `r.stats.quantile` for
example. That is: only one separator option is mentioned, the default
one. All manuals do mention all options though.
I'll have to look at this later on.
Thank you, Nikos
* Veronica Andreo <veroandreo at gmail.com> [2018-07-31 00:13:59 +0200]:
>How is it described in all other modules using the "separator" option?
>Maybe, it is worth checking and making it uniform.
>You could open a ticket and provide a diff file ;)
>cheers,
>Vero
>El dom., 29 jul. 2018 a las 11:46, Nikos Alexandris (<
>nik at nikosalexandris.net>) escribió:
>> One observation: `r.stats`'s `--help` returns
>> Parameters:
>>    separator   Field separator
>>                default: space
>> Shouldn't all separator options be listed here?
>> They are described in the `.html ` page:
>> separator=character
>>     Field separator
>>     Special characters: pipe, comma, space, tab, newline
>>     Default: space
>> Does this deserve a ticker?
>> Nikos
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180801/4fa89acf/attachment.sig>
