[GRASS-dev] pygrass v.import_() strange error
Yann Chemin dr.yann.chemin at gmail.com
Thu Aug 2 03:13:08 PDT 2018
yes this is the problem indeed
On Wed, 25 Jul 2018 at 13:21, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, Jul 25, 2018, 3:34 AM Yann Chemin <dr.yann.chemin at gmail.com>
> wrote:
>> Hi,
>> (script below)
>> I get this error
>> v.import_(input=adminfile,output="admin",quiet=True,superquiet=True)
>>   File "/usr/lib/grass74/etc/python/grass/pygrass/modules/shortcuts.py",
>> line 47, in __getattr__
>>     return self.cls('%s.%s' % (self.prefix, name.replace('_', '.')))
>>   File
>> "/usr/lib/grass74/etc/python/grass/pygrass/modules/interface/module.py",
>> line 530, in __init__
>>     raise GrassError(str_err % self.name)
>> grass.exceptions.GrassError: Error running: `v.import.
>> --interface-description`.
> It seems that PyGRASS does not support the "underscore at the end when
> Python keyword". It just does it's usual thing which is replacing
> underscores with dots like in r.slope_aspect. So probably a new
> functionality needs to be added to replace import_ with just import.
> Something like name.strip('_'). Please add a test for it.
> Best,
> Vaclav
>> #SCRIPT
>> from grass_session import Session
>> from grass.pygrass.modules.shortcuts import vector as v
>> adminfile=gadm_FR_2_Morbihan.gpkg
>> with Session(gisdb="/tmp", location="loc", create_opts="EPSG:4326"):
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180802/8b44d1b0/attachment.html>
