[GRASS-dev] [GRASS GIS] #3612: g.gui.tplot: error when calling from terminal
trac at osgeo.org
Thu Aug 2 17:14:10 PDT 2018
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.tplot | CPU: Unspecified
Platform: Linux |
When calling G7:g.gui.tplot from the terminal with:
g.gui.tplot strds=LST_Day_monthly_celsius
cordinates=641428.783478,229901.400746
only to get the time series plot of that place, I get the following error:
File "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-
gnu/scripts/g.gui.tplot", line 175, in <module>
main()
gnu/scripts/g.gui.tplot", line 162, in main
ylabel, csvfile, flags['h'], gscript .overwrite)
gnu/gui/wxpython/tplot/frame.py", line 1019, in SetDatasets
self._redraw()
gnu/gui/wxpython/tplot/frame.py", line 899, in _redraw
self._drawFigure()
gnu/gui/wxpython/tplot/frame.py", line 621, in _drawFigure
self.drawR()
gnu/gui/wxpython/tplot/frame.py", line 691, in drawR
if self.csvpath:
AttributeError: 'TplotFrame' object has no attribute 'csvpath'
However, if I run:
coordinates=641428.783478,229901.400746 csv=test.csv
then, it works. IMO `csv` should be an optional parameter (i.e., to be
used only if the user wants to export the values).
If using the GUI only, all goes fine.
I use trunk r73021 in Fedora 28.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3612>
