[GRASS-dev] [GRASS GIS] #3615: Two new functions for grass.script python lib
trac at osgeo.org
Tue Aug 14 01:13:16 PDT 2018
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.6.0
Component: Python | Version: svn-trunk
Resolution: | Keywords:
CPU: All | Platform: All
Comment (by sbl):
OK, I found:
https://grass.osgeo.org/grass74/manuals/libpython/script.html#script.task.cmdstring_to_tuple
so that one is fine.
The only remaining thing would then be to add a script.core.tempname()
function somewhere here I suppose:
https://grass.osgeo.org/grass75/manuals/libpython/script.html#script.core.tempdir
My function below would require additional imports though, hope that would
be OK...
Generated names are SQL and GRASS mp name compliant.
import string
import random
def tempname(length, lowercase=False):
"""Generate a random name of length "length" starting with a letter
:param int length: length of the random name to generate
:param bool lowercase: use only lowercase characters to generate name
:returns: String with a random name of length "length" starting with a
letter
:rtype: str
:Example:
>>> tempname(12)
'MxMa1kAS13s9'
if lowercase:
chars = string.ascii_lowercase + string.digits
else:
chars = string.ascii_uppercase + string.ascii_lowercase +
string.digits
randomname = '1'
while randomname[0].isdigit():
randomname = ''.join(random.choice(chars) for _ in range(length))
return randomname
Ticket URL: <https://trac.osgeo.org/grass/ticket/3615#comment:1>
