[GRASS-dev] [GRASS GIS] #2766: GUI not able to create dropdown lists of columns for more than one map or table
trac at osgeo.org
Tue Aug 14 08:09:00 PDT 2018
table
Reporter: lfurtkevicova | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.4
Component: wxGUI | Version: 7.0.1
Resolution: | Keywords: column lists
CPU: x86-64 | Platform: Linux
Comment (by pvanbosgeo):
Just was bitten by this issue. Just as a further specification, this is
not only a problem if one wants to specify columns in two different maps,
but also when one wants to select two columns (as two separate variables)
from the same map.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2766#comment:9>
