[GRASS-dev] [GRASS GIS] #3620: r.buffer crashes when trying to buffer rasterized polygons
GRASS GIS trac at osgeo.org
Wed Aug 15 13:46:45 PDT 2018
 Reporter:  dido            |      Owner:  grass-dev@…
     Type:  defect          |     Status:  new
 Priority:  major           |  Milestone:
Component:  Raster          |    Version:  7.4.0
 Keywords:  r.buffer crash  |        CPU:  x86-64
 Platform:  MSWindows 7     |
 At crash time r.buffer outputs this:
 Reading input raster map <defekti_rast at PERMANENT>...
  100%
 Finding buffer zones...
   57%
 > crash here
 Here is the windows crash log:
 Problem signature:
   Problem Event Name:   APPCRASH
   Application Name:     r.buffer.EXE
   Application Version:  7.4.0.0
   Application Timestamp:        5a6bcca6
   Fault Module Name:    r.buffer.EXE
   Fault Module Version: 7.4.0.0
   Fault Module Timestamp:       5a6bcca6
   Exception Code:       c0000005
   Exception Offset:     000000000000164c
   OS Version:   6.1.7601.2.1.0.256.48
   Locale ID:    1026
   Additional Information 1:     bbf7
   Additional Information 2:     bbf7706b53fbb0fa7695ff337b93e0f9
   Additional Information 3:     9d52
   Additional Information 4:     9d5215a4a4810f4d9a53d895d6bdf7b3
 Read our privacy statement online:
   http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
 If the online privacy statement is not available, please read our privacy
 statement offline:
   C:\Windows\system32\en-US\erofflps.txt
 Problem is manifested using a python script. Script and data provided as
 attachment.
 !!! The script must be tweaked slightly in the beginning to match the
 grass install path. A proper GRASS DB must be provided there with a BG_DEM
 location and a PERMANENT mapset projected in EPSG:32635 (UTM Z35N)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3620>
