[GRASS-dev] r.cost size limitations [was: Re: new addon: i.cutlines - Creates semantically meaningful tile borders]
Moritz Lennert
mlennert at club.worldonline.be
Thu Aug 16 07:41:02 PDT 2018
On 16/08/18 12:26, Moritz Lennert wrote:
> On 14/08/18 10:13, Moritz Lennert wrote:
>> On 13/08/18 15:30, Markus Neteler wrote:
>>> Hi Moritz,
>>> On Mon, Aug 13, 2018 at 2:04 PM, Moritz Lennert
>>> <mlennert at club.worldonline.be> wrote:
>>>> On 13/08/18 13:41, Markus Neteler wrote:
>>>> AFAIK, the only moment where i.cutlines potentially reads the whole image
>>>> would be in the edge detection part. That's why there is the tiling option
>>>> to avoid just that.
>>> I suppose you refer to
>>> tile_width=integer
>>> Width of tiles for tiled edge detection (pixels)
>>> tile_height=integer
>>> Height of tiles for tiled edge detection (pixels)
>>>> So, unless I'm forgetting something, you should be able
>>>> to work on large images. If you have seen this crash the module, please file
>>>> a bug report.
> A colleague working with a large dataset > 10e9 pixels) just reported
> that the module does not crash, but that it seems to take "forever" (he
> stopped the process after a day). I guess this is in the r.cost phase.
> An option would be to tile (and parallelize) the entire process which
> would mean finding cutlines in the individual tiles, making sure that
> the start and endpoints of these cutlines match the start and endpoints
> on the neighboring tiles...
I see this in r.cost's main.c:
420 /* this is most probably the limitation of r.cost for large datasets
421 * segment size needs to be reduced to avoid unecessary disk IO
422 * but it doesn't make sense to go down to 1
423 * so use 64 segment rows and cols for <= 200 million cells
424 * for larger regions, 32 segment rows and cols
425 * maybe go down to 16 for > 500 million cells ? */
So maybe it's time to experiment a bit more with r.cost in very large
regions ?
Moritz
