[GRASS-dev] [GRASS GIS] #3619: G_OPT_DB_WHERE - non-functional 'table' icon in gui
GRASS GIS trac at osgeo.org
Fri Aug 17 05:48:36 PDT 2018
  Reporter:  pvanbosgeo   |      Owner:  martinl
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:  7.4.2
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Linux
Comment (by martinl):
 This bug appears when you click on 'table' button before input vector map
 is selected. Steps to reproduce (in this case show on G74:v.extract):
 1. click on 'table' button (`where` option) -> reported traceback
  * fixed in r73114, error message "No vector map selected" appears
 2. select input map (with no attributes attached)
  * error message "No table linked to layer <1>"
 3. select input map with attributes attached
  * SQL Builder opens
 Anyway G74:v.vect.stats has another problem with GUI dependencies which
 needs to be fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3619#comment:4>
