[GRASS-dev] [GRASS GIS] #3537: Add functionalities –tmp-location and –no-clean
trac at osgeo.org
Sun Aug 19 12:57:44 PDT 2018
Reporter: radeknovotny94 | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.6.0
Component: Startup | Version: svn-trunk
Resolution: fixed | Keywords: tmp-location, no-clean, exec
CPU: All | Platform: All
Comment (by Nikos Alexandris):
A suggestion to check for if the 'geofile' (in `grass.py` named as
`geostring`) exists and if it is is readable:
https://trac.osgeo.org/grass/attachment/ticket/3537/grass.py_check_geostring.patch.
I believe to have tested this properly.
I could not follow what is recommended at
https://stackoverflow.com/a/82852/1172302.
In example, something like
try:
geostring = pathlib.Path(geostring)
geostring.resolve()
except IOError as e:
fatal(_("{error}"
"\n\n"
"Check spelling "
"or the file's read permissions.").format(error=e))
else:
# create location using georeferenced file
gcore.create_location(gisdbase, location,
filename=geostring)
would not test for read access. I could find a way to test for read access
using something from https://docs.python.org/3/library/pathlib.html.
Maybe this can be implemented by using "future" built-in exceptions as
FileNotFoundError (see https://docs.python.org/3/library/exceptions.html)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3537#comment:8>
