[GRASS-dev] d.vect.colhist
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Aug 21 01:14:14 PDT 2018
Hi Moritz,
I am trying out your addon d.vect.colhist. One problem I encountered was
that the 'table' button to define the 'WHERE' condition using the GUI
was not working (initial reason I filed the bug report
https://trac.osgeo.org/grass/ticket/3619). In the case of your addon,
what is missing (to make this work) is the layer selector:
#%option G_OPT_V_FIELD
#%end
Adding that will also make the 'table' button work.
Cheers,
Paulo
