[GRASS-dev] [GRASS GIS] #3448: v.buffer native failures
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Thu Aug 23 04:39:19 PDT 2018
Hi Marcus,
I am not too familiar with C and the like so I might confuse some things here...
I noticed that using .buffer() in PyGRASS gives a lot of "using native format" output.
So I looked it up and it seems to be using native buffering (Vect_area_buffer2):
https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/pygrass/vector/geometry.py#L1654
And Vect_area_buffer2 is the non-geos buffering, right?
https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.buffer/main.c#L564
So, should then PyGRASS be changed/fixed to use geos buffering too?
Shall I open a ticket?
Cheers,
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of GRASS GIS
Sent: onsdag 22. august 2018 22:07
Cc: grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] [GRASS GIS] #3448: v.buffer native failures
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.6.0
Component: Vector | Version: unspecified
Resolution: wontfix | Keywords: v.buffer v.parallel
CPU: Unspecified | Platform: Unspecified
Changes (by mmetz):
* status: new => closed
* resolution: => wontfix
Comment:
This is a long known issue and the reason why v.buffer uses GEOS buffering. GRASS native buffering will probably not be fixed because GEOS buffering is working, thus closing as won't fix.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3448#comment:4>
