[GRASS-dev] [GRASS GIS] #3537: Add functionalities –tmp-location and –no-clean
trac at osgeo.org
Thu Aug 23 16:30:34 PDT 2018
Reporter: radeknovotny94 | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.6.0
Component: Startup | Version: svn-trunk
Resolution: fixed | Keywords: tmp-location, no-clean, exec
CPU: All | Platform: All
Comment (by wenzeslaus):
Hi Nikos, I'm looking at this now and:
1) I can't reproduce the "if the file does not exist, the process hangs"
behavior from your [https://lists.osgeo.org/pipermail/grass-
user/2018-August/078970.html email]. I get `ERROR: ... xxx.xxx: No such
file or directory`.
2) This should be really a separate ticket because it is/would be a bug
(this is a closed enhancement ticket).
3) It is unrelated to `--tmp-location` unless you can show that it does
not happen with `-c` (important only for testing and reporting).
4) Your considerations about what to report based on what are the right
thing to do, let's discuss it in a new ticket of you can reproduce the
hanging or you have some other issues (like the message).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3537#comment:10>
