[GRASS-dev] [GRASS GIS] #934: d.vect with z height colors uses a random polygon point for height - patch to fix attached
trac at osgeo.org
Sat Aug 25 10:04:27 PDT 2018
to fix attached
Reporter: jarim | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.6.0
Component: Display | Version: svn-trunk
Resolution: fixed | Keywords: d.vect, z height color zcolor
CPU: x86-32 | Platform: All
Changes (by martinl):
* status: new => closed
* keywords: z height color zcolor => d.vect, z height color zcolor
* resolution: => fixed
Comment:
Z height computation for 3D lines/polygons changed accordingly in r73180.
Milestone changed to 7.6, the current behaviour in GRASS 7.4 and 7.2
should remain as it is (first vertex based). Explained in r73181 and
r73182.
Ticket URL: <https://trac.osgeo.org/grass/ticket/934#comment:10>
