[GRASS-dev] [GRASS GIS] #2732: Read lidar data as vector points using PDAL
trac at osgeo.org
Sun Aug 26 06:21:06 PDT 2018
Reporter: wenzeslaus | Owner: (none)
Type: | Status: new
enhancement |
Priority: major | Milestone: 7.6.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: lidar, las, laz, v.in.lidar,
CPU: | v.in.pointcloud, v.in.pdal
Unspecified | Platform: Unspecified
Comment (by martinl):
Replying to [comment:27 hellik]:
> recent pdal versions (pdal-1.7.2) are only available in 64bit OSGeo4W.
unfortunately `pdal` has a lot of dependencies:
eigen (3.2.1-1)
The Eigen library.
Required by: pdal
hexer (1.4.0-1)
Hexer: GDAL-based hexagon density and boundary binning
Required by: pdal
jq (1.5.0-0)
jq: command-line JSON processor
Required by: pdal
jsoncpp (1.6.0-1)
JsonCpp library
Required by: pdal
laszip (3.2.2-1)
The LASzip compression library
Required by: pdal
laz-perf (0.0.1-2)
Alternative LAZ implementation for C/C++ and JavaScript
Required by: pdal
nitro (2.8.7-5)
NITRO: C/C++ library for NITF manipulation
Required by: pdal
oci (12.1.0.1.0-1)
Oracle Instant Client
Required by: pdal
python3-core (3.6.0-2)
Python3 core interpreter and runtime
Required by: python3-numpy, python3-gdal, python3-matplotlib,
python3-pytz, python3-six, python3-cycler, python3-python-dateutil,
python3-pyparsing
python3-cycler (0.10.0-1)
Composable style cycles
Required by: python3-matplotlib
python3-gdal (2.2.4-1)
The GDAL/OGR Python3 Bindings and Scripts
Required by: pdal
python3-matplotlib (2.0.0-1)
Python plotting package
Required by: pdal
python3-numpy (1.12.0+mkl-1)
NumPy: array processing for numbers, strings, records, and
objects.
Required by: pdal, python3-gdal, python3-matplotlib
python3-pyparsing (2.1.10-1)
Python parsing module
python3-python-dateutil (2.6.0-1)
Extensions to the standard Python datetime module
python3-pytz (2018.3-1)
World timezone definitions, modern and historical
python3-six (1.11.0-1)
Python 2 and 3 compatibility utilities
Required by: python3-matplotlib, python3-cycler, python3-python-
dateutil
xz-devel (5.2.3-1)
XZ-format compression library - development files
Required by: pdal
It will enlarge standalone binaries significantly (especially Python3).
Would be nice to split OSGeo4W packages into `pdal` and `python3-pdal`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2732#comment:29>
