[GRASS-dev] Regarding More Contributions
Luca Delucchi lucadeluge at gmail.com
Sun Aug 26 08:28:55 PDT 2018
On Thu, 23 Aug 2018 at 06:35, Sunveer Singh <singhsunveer54 at gmail.com> wrote:
> Hi,
> How was the GSoC this year? Hope you guys enjoyed mentoring new students!
GSoC was hard but pleasant time
> I would like to contribute more tests, On which modules should I write test?
there are a lot of them... but some are really difficult, I suggest
you to look at the manual a choose someone that seems simple to you
r.buffer
r.buffer.lowmem
r.buildvrt
r.carve
r.category
r.circle
r.clump
r.coin
r.colors.out
r.composite
r.compress
r.contour
r.covar
r.cross
r.describe
r.distance
r.example
r.external
r.external.out
r.fill.dir
r.flow
r.his
r.in.aster
r.in.bin
r.in.gridatb
r.in.mat
r.in.srtm
r.in.wms
r.in.wms
r.in.xyz
r.kappa
r.lake
r.latlong
r.li
r.li.cwed
r.li.daemon
r.li.dominance
r.li.edgedensity
r.li.mpa
r.li.mps
r.li.padcv
r.li.padrange
r.li.padsd
r.li.patchdensity
r.li.patchnum
r.li.pielou
r.li.renyi
r.li.richness
r.li.shannon
r.li.shape
r.li.simpson
r.mfilter
r.neighbors
r.null
r.out.ascii
r.out.bin
r.out.gdal
r.out.gridatb
r.out.mat
r.out.mpeg
r.out.pov
r.out.ppm
r.out.ppm3
r.out.vrml
r.out.vtk
r.param.scale
r.plus.example
r.proj
r.quant
r.quantile
r.random
r.random.surface
r.reclass.area
r.region
r.regression.line
r.regression.multi
r.relief
r.resamp.bspline
r.resamp.filter
r.resamp.interp
r.resamp.rst
r.resamp.stats
r.resample
r.rescale
r.rescale.eq
r.ros
r.sim.sediment
r.sim.water
r.solute.transport
r.spread
r.spreadpath
r.statistics
r.stats.quantile
r.stats.zonal
r.stream.extract
r.sunhours
r.sunmask
r.support
r.support.stats
r.surf.area
r.surf.contour
r.surf.fractal
r.surf.gauss
r.surf.idw
r.surf.random
r.terraflow
r.thin
r.tile
r.to.rast3elev
r.topidx
r.topmodel
r.transect
r.uslek
r.usler
r.volume
r.walk
r.water.outlet
r.watershed
r.what
r.what.color
r3.cross.rast
r3.gwflow
r3.in.ascii
r3.in.lidar
r3.in.v5d
r3.in.xyz
r3.info
r3.mask
r3.mkdspf
r3.out.ascii
r3.out.bin
r3.out.v5d
r3.out.vtk
r3.retile
r3.showdspf
r3.stats
r3.support
t.create
t.list
t.rast.colors
t.rast.list
t.rast.mapcalc
t.rast.out.vtk
t.rast3d.mapcalc
t.register
t.remove
t.rename
t.select
t.topology
t.vect.db.select
t.vect.export
t.vect.what.strds
v.buffer
v.build
v.build.all
v.build.polylines
v.class
v.cluster
v.colors
v.colors.out
v.db.connect
v.decimate
v.delaunay
v.drape
v.example
v.external
v.external.out
v.extrude
v.generalize
v.hull
v.import
v.in.db
v.in.dwg
v.in.dxf
v.in.e00
v.in.geonames
v.in.mapgen
v.in.ogr
v.in.region
v.in.wfs
v.kcv
v.kernel
v.label
v.label.sa
v.lidar.correction
v.lidar.edgedetection
v.lidar.growing
v.lrs
v.lrs.create
v.lrs.label
v.lrs.segment
v.lrs.where
v.mkgrid
v.neighbors
v.net.alloc
v.net.allpairs
v.net.bridge
v.net.centrality
v.net.components
v.net.connectivity
v.net.distance
v.net.flow
v.net.iso
v.net.path
v.net.salesman
v.net.spanningtree
v.net.steiner
v.net.timetable
v.net.visibility
v.normal
v.out.ascii
v.out.dxf
v.out.ogr
v.out.postgis
v.out.pov
v.out.svg
v.out.vtk
v.outlier
v.overlay
v.parallel
v.patch
v.perturb
v.proj
v.qcount
v.random
v.reclass
v.rectify
v.sample
v.segment
v.split
v.support
v.surf.idw
v.to.db
v.to.points
v.to.rast
v.to.rast3
v.transform
v.type
v.vol.rst
v.voronoi
v.what.rast
> Thank You
> Sunveer
> https://sunveersingh.github.io/
ciao
Luca
www.lucadelu.org
