[GRASS-dev] [GRASS GIS] #3629: cannot click to check/uncheck accessible mapsets in g.mapsets
trac at osgeo.org
Mon Aug 27 10:37:55 PDT 2018
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: wxGUI | Version: svn-trunk
Keywords: g.mapsets, mapset access | CPU: Unspecified
Platform: Unspecified |
g.mapsets GUI lists potential mapsets to access but there is no way to
check or uncheck them. I've tried clicking, double clicking, control/right
clicking. Nothing happens. The command works OK from the terminal but not
from the GUI. I just noticed this in 7.5. I don't know if it is a problem
in 7.4, but probably.
Is this Mac only or a larger issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3629>
