[GRASS-dev] importing QGIS dbf table question
Michael Barton Michael.Barton at asu.edu
Mon Aug 27 12:07:10 PDT 2018
I’m recently having trouble importing the dbf table of a shape file (generated by QGIS) into GRASS 7.2 to 7.5. I get the error listed below. I don’t know if it is a bug I need to report or something wrong with the table. Has anyone else run into similar issues?
SQLITE works fine on existing GRASS vectors. I just can’t import some shape files recently.
Michael
v.import -o --overwrite input=/Users/cmbarton/Dropbox (ASU)/Conferences&Meetings/2018/EAA 2018/data/SP_NV_7_GIS_DATA/SP_NV_07_column_location.shp layer=SP_NV_07_column_location
Over-riding projection check
Check if OGR layer <SP_NV_07_column_location> contains polygons...
WARNING: Vector map <SP_NV_07_column_location> already exists and will be overwritten
dyld: Library not loaded: @rpath/libncurses.6.dylib
  Referenced from: /Applications/GRASS-7.2.2.app/Contents/Re
sources/lib/libsqlite3.0.dylib
  Reason: image not found
dbmi: Protocol error
WARNING: Unable to start driver <sqlite>
WARNING: Unable open database </Users/cmbarton/Dropbox (ASU)/GRASS_dropbox/grassdata_dropbox/Global_latlon/EAA2018/sqlite/sqlite.db> by driver <sqlite>
WARNING: Unable to find table <SP_NV_07_column_location> linked to vector map <SP_NV_07_column_location>
ERROR: Unable to open database </Users/cmbarton/Dropbox (ASU)/GRASS_dropbox/grassdata_dropbox/Global_latlon/EAA2018/sqlite/sqlite.db> by driver <sqlite>
ERROR: Unable to import </Users/cmbarton/Dropbox (ASU)/Conferences&Meetings/2018/EAA 2018/data/SP_NV_7_GIS_DATA/SP_NV_07_column_location.shp>
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ  85287-2402
USA
voice:    480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www:      http://csdc.asu.edu, http://shesc.asu.edu
                                http://www.public.asu.edu/~cmbarton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180827/a2fc7d00/attachment.html>
