[GRASS-dev] importing QGIS dbf table question
Michael Barton
Michael.Barton at asu.edu
Tue Aug 28 09:29:40 PDT 2018
Turns out this is a GRASS 7.2.2 issue but not a 7.4/7.5 issue. I'll have to see if there is a difference in compiling that could account for this.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On 8/28/18, 4:15 AM, "grass-dev on behalf of grass-dev-request at lists.osgeo.org" <grass-dev-bounces at lists.osgeo.org on behalf of grass-dev-request at lists.osgeo.org> wrote:
Date: Tue, 28 Aug 2018 00:01:07 +0200
To: Michael Barton <Michael.Barton at asu.edu>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] importing QGIS dbf table question
Message-ID:
<CALFmHhvaoVg+aL8qFtpKtUMtLTZhBM2ExC9_hzSC8n6s8Azw_w at mail.gmail.com>
Content-Type: text/plain; charset="UTF-8"
On Mon, Aug 27, 2018 at 9:07 PM Michael Barton <Michael.Barton at asu.edu> wrote:
>I’m recently having trouble importing the dbf table of a shape file (generated by QGIS) into GRASS 7.2 to 7.5. I get the error listed below. I don’t know if it is a bug I need to report or something wrong with the table. Has anyone else run into similar issues?
>SQLITE works fine on existing GRASS vectors. I just can’t import some shape files recently.
>v.import -o --overwrite input=/Users/cmbarton/Dropbox (ASU)/Conferences&Meetings/2018/EAA 2018/data/SP_NV_7_GIS_DATA/SP_NV_07_column_location.shp layer=SP_NV_07_column_location
>Over-riding projection check
>Check if OGR layer <SP_NV_07_column_location> contains polygons...
>WARNING: Vector map <SP_NV_07_column_location> already exists and will be overwritten
>dyld: Library not loaded: @rpath/libncurses.6.dylib
> Referenced from: /Applications/GRASS-7.2.2.app/Contents/Resources/lib/libsqlite3.0.dylib
> Reason: image not found
>dbmi: Protocol error
>WARNING: Unable to start driver <sqlite>
I see two issues:
- libncurses missing or not found
- libsqlite3 missing: image not found
Maybe a system update brought in troubles?
Markus
