[GRASS-dev] r.series method=minimum yields float map when integer maps are used as input
Veronica Andreo veroandreo at gmail.com
Thu Aug 30 05:13:38 PDT 2018
El mié., 29 ago. 2018 a las 22:37, Markus Metz (<
markus.metz.giswork at gmail.com>) escribió:
> On Tue, Aug 28, 2018 at 1:49 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
> > Sorry, I pressed send earlier than intended...
> > El mar., 28 ago. 2018 a las 13:45, Veronica Andreo (<
> veroandreo at gmail.com>) escribió:
> >> Thanks for the explanation, Glynn :)
> >> El mar., 28 ago. 2018 a las 11:01, Glynn Clements (<
> glynn at gclements.plus.com>) escribió:
> >>> Veronica Andreo wrote:
> >>> > If I use a series of integer type maps as input to t.rast.series or
> >>> > r.series and select minimum as method, the output is a floating
> point map.
> >>> > I would have thought that if the input are integers then output
> should be
> >>> > integer as well. I realized when I made a plot of the map and got a
> smooth
> >>> > legend instead of integer numbers.
> >>> > Is this an expected behaviour?
> >>> The type of the output map is independent of the inputs, determined
> >>> solely by the method. The count, diversity, min_raster and max_raster
> >>> methods generate integer maps; all other methods generate
> >>> floating-point maps.
> >>> It probably wouldn't be particularly involved to add another flag to
> >>> the method table to indicate that a particular method will always
> >>> produce an integer result for integer inputs.
> > Is this worth an enhancement ticket? I do not know how to implement any
> of this myself.
> Please try trunk r73206.
Works as expected :)
Thanks a million, Markus!
Cheers,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180830/e6cde5e9/attachment.html>
