[GRASS-dev] [GRASS GIS] #3701: i.sentinel.prep fails with southern hemisphere Sentinel 2 level 1 data
trac at osgeo.org
Tue Dec 4 21:43:24 PST 2018
Reporter: geomax22 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: | CPU: x86-64
Platform: MSWindows |
Using Sentinel S2A_MSIL1C from USGS in an area in Western Australia (UTM
Zone 50 South ) fails when trying to create an input file for
i.sentinel.mask with the error:
"C:\Users\Max\AppData\Roaming\GRASS7\addons\scripts\i.sentinel.preproc.py
-a -t
input_dir=E:\S2_Abrholos\Sentinel\S2A_MSIL1C_20181128T021341_N0207_R060_T50JKN_20181128T080405.SAFE
elevation=bathy_LL_sub_utm50 at S2 atmospheric_model=Automatic
aerosol_model=Continental model aod_value=0.07 suffix=depth
text_file=mask_prep
ERROR: Latitude -29.3983025 is out of range
(Wed Dec 05 13:13:03 2018) Command finished (7 sec)
All works fine with imagery in the northern hemisphere.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3701>
