[GRASS-dev] [GRASS-SVN] r73769 - grass/trunk/locale/po
Huidae Cho
grass4u at gmail.com
Fri Dec 7 08:14:00 PST 2018
Yes, I did use the transifex_merge script (changed -a to -l ko).
Huidae
On Thu, Dec 6, 2018 at 2:53 AM Markus Neteler <neteler at osgeo.org> wrote:
> Hi Huidae,
> On Wed, Dec 5, 2018 at 1:39 PM <svn_grass at osgeo.org> wrote:
> > Author: hcho
> > Date: 2018-12-05 04:39:10 -0800 (Wed, 05 Dec 2018)
> > New Revision: 73769
> > Modified:
> > grass/trunk/locale/po/grasslibs_ko.po
> > grass/trunk/locale/po/grassmods_ko.po
> > grass/trunk/locale/po/grasswxpy_ko.po
> > Log:
> > i18n: Update Korean POs
> just a question: did you update this using the transifex_merge script?
> Otherwise the work may get lost until we have "tx push" working.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
Open Source GIS Developer, GRASS GIS Development Team
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181207/8010deef/attachment.html>
