[GRASS-dev] [GRASS GIS] #3446: GRASS python library is not working with python 3
trac at osgeo.org
Mon Dec 10 13:55:30 PST 2018
Reporter: lrntct | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.8.0
Component: Python | Version: 7.2.1
Resolution: | Keywords: python python3 ctypes, python 3.7
CPU: x86-64 | Platform: Linux
Comment (by neteler):
Now I have an issue with g.extension:
GRASS 7.7.svn (utm32N):~ > python --version
Python 3.7.1
GRASS 7.7.svn (utm32N):~ > g.extension i.fusion.hpf
Fetching <i.fusion.hpf> from GRASS GIS Addons repository (be patient)...
File "/home/mneteler/software/grass77/dist.x86_64-pc-linux-
gnu/scripts/g.extension", line 1758, in <module>
sys.exit(main())
gnu/scripts/g.extension", line 1737, in main
install_extension(source=source, url=url, xmlurl=xmlurl)
gnu/scripts/g.extension", line 697, in install_extension
source=source, url=url)
gnu/scripts/g.extension", line 1160, in install_extension_std_platforms
outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
gnu/scripts/g.extension", line 1113, in download_source_code
fix_newlines(directory)
gnu/scripts/g.extension", line 1043, in fix_newlines
if '\0' in data:
TypeError: a bytes-like object is required, not 'str'
Likewise with other addon modules to be installed...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3446#comment:19>
