[GRASS-dev] i.sentinel improvements
Markus Neteler
neteler at osgeo.org
Wed Dec 19 03:36:30 PST 2018
On Wed, Dec 19, 2018 at 10:04 AM Roberta Fagandini
<robifagandini at gmail.com> wrote:
> Il giorno lun 17 dic 2018 alle ore 10:39 Luca Delucchi <lucadeluge at gmail.com> ha scritto:
>> - i.sentinel.preproc add capability to compute topographic correction
>> using the following prcedure
> I don't have much experience with topographic correction but I'm not sure that c-factor is the best. When I tested it, I got anomalous results.
> However, I would add the topographic correction as an option (e.g -flag "also perform topo cor")
Since there are different method in i.topo.corr, perhaps instead of a
flag use a parameter? Like:
topo_method=c-factor|minnaert|...
Markus
