[GRASS-dev] [GRASS GIS] #3193: r.out.gdal: add AUTHORITY node to the srs info of the exported raster
trac at osgeo.org
Thu Feb 1 03:31:03 PST 2018
Reporter: hellik | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.4.1
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal,r.external.out
CPU: All | Platform: All
Comment (by hellik):
Replying to [comment:10 mmetz]:
> Replying to [comment:9 hellik]:
> > Replying to [comment:6 mmetz]:
> > > Replying to [comment:5 martinl]:
> > > > This functionality was recently implemented in trunk, right?
Reference is missing here.
> > > It was implemented by martinl with r71303
> > tested with the example above:
> > AUTHORITY["EPSG","31255"]
> > seems to be still missing
> The functions were implemented in r71303. An EPSG code was only exported
with v.out.ogr. As of trunk r72160, an existing EPSG code is exported with
r.external.out, r.out.gdal, v.external.out, v.out.ogr.
tested with
System Info
GRASS version: 7.5.svn
GRASS SVN revision: r72194
Build date: 2018-01-30
Build platform: x86_64-w64-mingw32
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
g.proj -p
-PROJ_INFO-------------------------------------------------
name : MGI / Austria GK Central
datum : hermannskogel
ellps : bessel
proj : tmerc
lat_0 : 0
lon_0 : 13.33333333333333
k : 1
x_0 : 0
y_0 : -5000000
no_defs : defined
towgs84 : 577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
-PROJ_EPSG-------------------------------------------------
epsg : 31255
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
gdalinfo test_raster_authority.tif
Driver: GTiff/GeoTIFF
Files: test_raster_authority.tif
Size is 170, 141
Coordinate System is:
PROJCS["MGI / Austria GK Central",
GEOGCS["MGI",
DATUM["Militar_Geographische_Institute",
SPHEROID["Bessel 1841",6377397.155,299.1528128,
AUTHORITY["EPSG","7004"]],
TOWGS84[577.326,90.129,463.919,5.1366,1.4742,5.297,2.4232],
AUTHORITY["EPSG","6312"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4312"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",13.33333333333333],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",-5000000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","31255"]] <=
Origin = (-161500.000000000000000,273250.000000000000000)
Pixel Size = (250.000000000000000,-250.000000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=GRASS GIS 7.5.svn with GDAL 2.2.3
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -161500.000, 273250.000) ( 11d11'10.74"E, 47d34'42.28"N)
Lower Left ( -161500.000, 238000.000) ( 11d11'56.99"E, 47d15'41.55"N)
Upper Right ( -119000.000, 273250.000) ( 11d45' 3.81"E, 47d35'15.35"N)
Lower Right ( -119000.000, 238000.000) ( 11d45'37.92"E, 47d16'14.25"N)
Center ( -140250.000, 255625.000) ( 11d28'27.33"E, 47d25'29.61"N)
AUTHORITY["EPSG","XXXX"] is now exported in rasters too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:14>
