[GRASS-dev] [GRASS GIS] #3488: v.in.ogr mangeling of column names when imporing OSM geojson extracts
GRASS GIS trac at osgeo.org
Fri Feb 2 01:33:55 PST 2018
 Reporter:  alice     |      Owner:  grass-dev@…
     Type:  defect    |     Status:  new
 Priority:  normal    |  Milestone:  7.4.1
Component:  Vector    |    Version:  svn-releasebranch74
 Keywords:  v.in.ogr  |        CPU:  All
 Platform:  Linux     |
 I tried to import geojson extracts from http://overpass-turbo.eu/ with the
 query `highway=* and type:way` for the area of Bonn. When importing it
 with v.in.ogr appeared:
 Error in sqlite3_prepare():
 duplicate column name: sloped_curb_end
 This happens whenever changing the column names from  name:name to
 name_name, and whenever name_name is already existing in the dataset, it
 stops and gives an error.
 It would be nice to find a different solution while changing : of the
 initial column names, maybe with whenever changing a : into _ adding a 1
 at the end of the new name in order to prevent the creation of duplicates.
 Geojson file attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3488>
