[GRASS-dev] r.in.gdal changes range of values for sentinel bands (?)
Markus Metz
markus.metz.giswork at gmail.com
Mon Feb 5 10:49:13 PST 2018
On Mon, Feb 5, 2018 at 1:14 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> I tested also with 74 release branch... same result
> 2018-02-05 13:05 GMT+01:00 Veronica Andreo <veroandreo at gmail.com>:
>> Hi devs
>> I'm testing Martin's new add-on, r.sentinel.import. I created an UTM21S
location for my data and imported them with:
>> r.sentinel.import
input=Downloads/S2B_MSIL1C_20171212T134159_N0206_R124_T21KZP_20171212T201017.SAFE/GRANULE/L1C_T21KZP_A004011_20171212T134158/IMG_DATA/
>> The problem arose when I tried to use i.color.enhance to display an RGB:
I got blank screens, so I thought there must be something with the range of
values.
>> r.univar map=T21KZP_20171212T134159_B02 at PERMANENT
>> total null and non-null cells: 120560400
>> total null cells: 0
>> Of the non-null cells:
>> n: 120560400
>> minimum: 15
>> maximum: 17547
>> range: 17532
>> mean: 913.778
>> mean of absolute values: 913.778
>> standard deviation: 134.322
>> variance: 18042.4
>> variation coefficient: 14.6996 %
>> sum: 110165471238
>> that already seemed odd...
>> I checked the original band2 jp2 file... Values are different...
>> gdalinfo T21KZP_20171212T134159_B02.jp2
>> Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
>> Files: T21KZP_20171212T134159_B02.jp2
>> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
>> Min=602.000 Max=1576.000
>> Minimum=602.000, Maximum=1576.000, Mean=916.799, StdDev=123.509
>> Overviews: 5490x5490, 2745x2745, 1372x1372, 686x686
>> Overviews: arbitrary
>> Metadata:
>> STATISTICS_MAXIMUM=1576
>> STATISTICS_MEAN=916.7992
>> STATISTICS_MINIMUM=602
>> STATISTICS_STDDEV=123.50943477872
>> Image Structure Metadata:
>> COMPRESSION=JPEG2000
>> NBITS=15
Can you try again with gdalinfo -mm? This forces computation of the actual
min/max values, which can differ from what is stored in the metadata (an
approximation).
There can also be something wrong with i.color.enhance
Markus M
>> Just to check, I imported with r.in.gdal and I'm getting exactly the
same as with r.sentinel.import.
>> What am I doing wrong here? Why would r.in.gdal change values like that?
What else needs to be set? I don't remember to have this problem before and
it happens in all bands as far as I've checked.
>> Ah, I'm using trunk r72203
>> Thanks in advance for any help :)
>> Cheers,
>> Vero
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180205/164515f9/attachment-0001.html>
