[GRASS-dev] r.in.gdal changes range of values for sentinel bands (?)
Veronica Andreo
veroandreo at gmail.com
Tue Feb 6 01:25:00 PST 2018
Sorry, sorry... that was a different band... I realize now. So, for the
record, no issues,
gdalinfo -mm T21KZP_20171212T134159_B02.jp2
reports the same range as the one I see after importing in grass.
Computed Min/Max=15.000,17547.000
Again, sorry for the noise and thanks for the -mm hint, MM :)
best,
Vero
2018-02-05 20:54 GMT+01:00 Veronica Andreo <veroandreo at gmail.com>:
> Forgot the list, sorry...
> Hi Markus,
> here the output of gdalinfo -mm for the same band reported earlier:
> gdalinfo -mm T21KZP_20171212T134159_B01.jp2
> Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
> Files: T21KZP_20171212T134159_B01.jp2
> Band 1 Block=192x192 Type=UInt16, ColorInterp=Gray
> Min=908.000 Max=1511.000 Computed Min/Max=934.000,6934.000
> Minimum=908.000, Maximum=1511.000, Mean=1138.806, StdDev=74.933
> Overviews: 915x915, 457x457, 228x228, 114x114
> Overviews: arbitrary
> Metadata:
> STATISTICS_MAXIMUM=1511
> STATISTICS_MEAN=1138.8064
> STATISTICS_MINIMUM=908
> STATISTICS_STDDEV=74.933459275813
> Image Structure Metadata:
> COMPRESSION=JPEG2000
> NBITS=15
> still differs a lot from what I get after importing into GRASS.
> System Info
> GRASS version: 7.5.svn
> GRASS SVN revision: r72203
> Build date: 2018-01-01
> Build platform: x86_64-pc-linux-gnu
> GDAL: 2.1.3
> PROJ.4: 4.9.3
> GEOS: 3.6.1
> SQLite: 3.20.1
> Python: 2.7.14
> wxPython: 3.0.2.0
> Platform: Linux-4.14.14-200.fc26.x86_64-x86_64-with-fedora-26-Twenty_Six
> best,
> Vero
> 2018-02-05 19:49 GMT+01:00 Markus Metz <markus.metz.giswork at gmail.com>:
>> On Mon, Feb 5, 2018 at 1:14 PM, Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>> > I tested also with 74 release branch... same result
>> > 2018-02-05 13:05 GMT+01:00 Veronica Andreo <veroandreo at gmail.com>:
>> >> Hi devs
>> >> I'm testing Martin's new add-on, r.sentinel.import. I created an
>> UTM21S location for my data and imported them with:
>> >> r.sentinel.import input=Downloads/S2B_MSIL1C_201
>> 71212T134159_N0206_R124_T21KZP_20171212T201017.SAFE/GRANULE/
>> L1C_T21KZP_A004011_20171212T134158/IMG_DATA/
>> >> The problem arose when I tried to use i.color.enhance to display an
>> RGB: I got blank screens, so I thought there must be something with the
>> range of values.
>> >> r.univar map=T21KZP_20171212T134159_B02 at PERMANENT
>> >> total null and non-null cells: 120560400
>> >> total null cells: 0
>> >> Of the non-null cells:
>> >> n: 120560400
>> >> minimum: 15
>> >> maximum: 17547
>> >> range: 17532
>> >> mean: 913.778
>> >> mean of absolute values: 913.778
>> >> standard deviation: 134.322
>> >> variance: 18042.4
>> >> variation coefficient: 14.6996 %
>> >> sum: 110165471238
>> >> that already seemed odd...
>> >> I checked the original band2 jp2 file... Values are different...
>> >> gdalinfo T21KZP_20171212T134159_B02.jp2
>> >> Files: T21KZP_20171212T134159_B02.jp2
>> >> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
>> >> Min=602.000 Max=1576.000
>> >> Minimum=602.000, Maximum=1576.000, Mean=916.799, StdDev=123.509
>> >> Overviews: 5490x5490, 2745x2745, 1372x1372, 686x686
>> >> Metadata:
>> >> STATISTICS_MAXIMUM=1576
>> >> STATISTICS_MEAN=916.7992
>> >> STATISTICS_MINIMUM=602
>> >> STATISTICS_STDDEV=123.50943477872
>> >> NBITS=15
>> Can you try again with gdalinfo -mm? This forces computation of the
>> actual min/max values, which can differ from what is stored in the metadata
>> (an approximation).
>> There can also be something wrong with i.color.enhance
>> Markus M
>> >> Just to check, I imported with r.in.gdal and I'm getting exactly the
>> same as with r.sentinel.import.
>> >> What am I doing wrong here? Why would r.in.gdal change values like
>> that? What else needs to be set? I don't remember to have this problem
>> before and it happens in all bands as far as I've checked.
>> >> Ah, I'm using trunk r72203
>> >> Thanks in advance for any help :)
>> >> Cheers,
>> >> Vero
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180206/44191a61/attachment.html>
