[GRASS-dev] [GRASS GIS] #3489: integrate grass session lib
GRASS GIS trac at osgeo.org
Tue Feb 6 07:59:09 PST 2018
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  Python       |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by wenzeslaus):
 Replying to [comment:4 zarch]:
 > Replying to [ticket:3489 martinl]:
 > > it would be nice to integrate Python grass_session lib (1) into GRASS
 code base.
 > However, for me the main advantage of `grass_session` library is that it
 is a "standard" python library, that is installed to the python
 interpreter as other libraries do.
 > Once that you have installed it, you can open your python interpreter
 and use it without the need of setting python paths, etc.
 Agreed. Although I'm not sure how to put it together with GRASS GIS
 libraries (in relation to code/distribution), the separate library
 promises better, more convenient, use for the end user.
 See also #2873 for an extensive discussion. One alternative solution is to
 put GRASS libraries (Python and C) on path (see #2873 and also #2424).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3489#comment:5>
