[GRASS-dev] [GRASS GIS] #789: g.region option to expand the computational region of about "some" pixels?
trac at osgeo.org
Thu Feb 8 00:03:54 PST 2018
Reporter: nikos | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 7.4.1
Component: Default | Version: unspecified
Resolution: | Keywords: g.region, expand computational
CPU: | region
Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:24 lucadelu]:
> Replying to [comment:22 martinl]:
> > Replying to [comment:21 lucadelu]:
> > > but nothing changed in the output of g.region -p, so no idea...
> > try
> > g.region -p3
> Thanks Martin, top and bottom are used only for 3D region? If yes I
don't think that pixels option should modify them....
Why not ? If you have the same use case as the one described by Nikos, but
with a 3D point map, wouldn't you need the same functionality also in top
and bottom direction ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/789#comment:25>
