[GRASS-dev] [GRASS GIS] #789: g.region option to expand the computational region of about "some" pixels?
trac at osgeo.org
Thu Feb 8 11:38:09 PST 2018
Reporter: nikos | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 7.4.1
Component: Default | Version: unspecified
Resolution: | Keywords: g.region, expand computational
CPU: | region
Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:26 lucadelu]:
> Replying to [comment:25 mlennert]:
> > Why not ? If you have the same use case as the one described by Nikos,
but with a 3D point map, wouldn't you need the same functionality also in
top and bottom direction ?
> For me it is the same, but probably I would like to have a flag to
modify the 3D region to use with pixels option
Either have one option that modifies extents of all 3 dimensions, or have
separate options for each dimension, e.g. xpixels, ypixels, zpixels. I
favour the first solution, one option for all 3 dimensions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/789#comment:27>
