[GRASS-dev] [GRASS GIS] #3496: v.in.pdal: does not compile with PDAL 1.6.0
GRASS GIS trac at osgeo.org
Thu Feb 15 19:20:32 PST 2018
  Reporter:  felixg       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Vector       |    Version:  unspecified
Resolution:               |   Keywords:  v.in.pdal, PDAL, lidar
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by wenzeslaus):
 Thank you. I committed the change in r72246. Tested with 1.5.0 and 1.6.0
 (compiled) and trunk using the two tests in testsuite directory:
 export LD_LIBRARY_PATH="/home/.../install/lib:$LD_LIBRARY_PATH"
 cd vector/v.in.pdal/testsuite
 ../../../bin.x86_64-pc-linux-gnu/grass75
 ~/grassdata/nc_basic_spm_grass7/user1/ \
     --exec python basic_test.py
     --exec python filter_test.py
 This can be closed after backport to 7.4 (and maybe 7.2).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496#comment:2>
