[GRASS-dev] [GRASS GIS] #3485: Introduce a new 64-bit integer raster data type
GRASS GIS trac at osgeo.org
Fri Feb 16 08:31:59 PST 2018
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  8.0.0
 Component:  LibRaster    |    Version:  svn-trunk
Resolution:               |   Keywords:  raster 64-bit
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:2 mlennert]:
 > Replying to [comment:1 mmetz]:
 > > Replying to [ticket:3485 mlennert]:
 > > > From #3084:
 > > > "Most importantly, a GRASS raster format for 64-bit signed integer.
 Note that GDAL does not support 64-bit signed or unsigned integers. The
 reason is probably that a portable implementation of 64-bit integers is
 not so easy. Regarding GRASS raster processing, the need for 64-bit
 integers usually arises only for raster maps with more than 2,147,483,647
 cells which in turn usually requires Large File Support (LFS). Therefore
 the check for the availability of a 64-bit integer could be coupled to
 LFS. If support for 64-bit signed integer raster maps (say, LCELL) could
 be added to GRASS, users would need to stick to GRASS since GDAL raster
 export of 64-bit integers is not available. Interesting idea."
 > > A 64 bit signed integer type has been added to trunk with r72230.
 Various other projects, e.g. GDAL, SQLite, HDF5, Python also have some 64
 bit signed integer type. In order to avoid namespace collision, the new
 type has been defined as grass_int64 and LCELL. GRASS libraries and
 modules do not yet make use of this type. Defining a 64 bit signed integer
 type has been tested on Linux + gcc, FreeBSD + clang, and MS Windows + gcc
 (mingw).
 > Great, thanks a lot, Markus !
 > What is the roadmap from here, not in terms of calendar, but in terms of
 tasks that need to be done to actually be able to use this new integer
 type ?
 Regarding internal variables, e.g. cell count, the first task would be to
 use the new 64 bit int type there instead of e.g. long which is sometimes
 32 bit and sometimes 64 bit. I think there are still some places where int
 is used for cell counts.
 Making such variables 64 bit integer would be a bug fix, considering that
 large raster data are nowadays commonly processed.
 Further on, some ifdefs like
 #ifdef HAVE_LONG_LONG_INT
 #endif
 could be removed. Such ifdefs would need to be kept for printing messages,
 unless the length modifier j is available on all supported systems (no
 idea here).
 A different issue is the introduction of a new LCELL raster map type. It
 should not be too difficult, but it would be a lot of work to add the
 corresponding functions, essentially cloning all the CELL type related
 functions and adjusting for LCELL.
 Replying to [comment:3 rouault]:
 > Related GDAL ticket: https://trac.osgeo.org/gdal/ticket/7052
 Regarding nodata, GRASS does not have a global nodata type, but we would
 need new fns like
 int Rast_is_l_null_value(const LCELL * lcellVal);
 void Rast_set_l_null_value(LCELL * lcellVals, int numVals);
 Still, such 64 bit integer GRASS raster maps could not be exported via
 GDAL.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3485#comment:4>
