[GRASS-dev] [GRASS GIS] #3498: Can't open NetCDF file
trac at osgeo.org
Sat Feb 17 03:53:53 PST 2018
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.1
Component: Default | Version: 7.4.0
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by mankoff):
And the reason the projection is slightly different than your `gdalinfo`
output is because since I posted the file I realized I need to set the
`-a` flag to `g.region` so that the resolution is not rounded to a strange
number. My `gdalinfo` output contains:
polar_stereographic#false_easting=0
polar_stereographic#false_northing=0
polar_stereographic#GeoTransform=-655000 5000 0 -630000 0 -5000
polar_stereographic#grid_mapping_name=polar_stereographic
polar_stereographic#inverse_flattening=298.257223563
polar_stereographic#latitude_of_projection_origin=90
polar_stereographic#longitude_of_prime_meridian=0
polar_stereographic#long_name=CRS definition
polar_stereographic#semi_major_axis=6378137
polar_stereographic#spatial_ref=PROJCS[
polar_stereographic#standard_parallel=70
polar_stereographic#straight_vertical_longitude_from_pole=-45
Note that regardless of this, I'm using the `-o` flag to `r.in.gdal`, and
it works in grass 7.2.0. I thought the `-o` flag means the projection
information, which may or may not be present and/or correct, is ignored.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3498#comment:3>
