[GRASS-dev] Issue with double conditional in r.mapcalc (WinGRASS) and real life test of the aconda 7.5dev on Mac
Yann Chemin dr.yann.chemin at gmail.com
Tue Feb 20 03:16:48 PST 2018
We had a mix of installations on Windows:
1 - QGIS standalone with GRASS7.2.2. (GRASS could also be run standalone it seems)
2 - WinGRASS 7.4.0. mostly direct install, but maybe some from OSGEO4W too.
3 - WinGRASS7.5svn nightly
Windows machines were many times not up to date, we even had some Windows7, but mostly Windows 8 and W10.
We tried to use the command prompt to enter the scripts, but it made trouble so we tried on the wxGUI Console, and we found it worked mostly, until we started entering more complex if statements. But that was after we had to remove quotes to enter the r.mapcalc script successfully anyway.
Would that be related to the issues with internationalisation (https://trac.osgeo.org/grass/ticket/3500 <https://trac.osgeo.org/grass/ticket/3500>)?
> On 18 Feb 2018, at 23:32, Helmut Kudrnovsky <hellik at web.de> wrote:
>> I conducted a GRASS GIS course this week and we found some bugs on WinGRASS:
> the subject of this report is _(WinGRASS)_ and _aconda 7.5dev on Mac_ ....
> which winGRASS version have you used? 7.4.0? 7.5dev? another version?
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180220/18ac816c/attachment.html>
