[GRASS-dev] [GRASS GIS] #3499: Backport of new ZSTD compression
trac at osgeo.org
Wed Feb 21 12:30:02 PST 2018
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.1
Component: LibRaster | Version: unspecified
Resolution: | Keywords: ZSTD compression
CPU: All | Platform: All
Comment (by mmetz):
Replying to [comment:1 mmetz]:
> Replying to [ticket:3499 neteler]:
> > Carried over from #2750
> > Replying to [#2750 comment:69 neteler]:
> > > Concerning ZSTD compression: backport candidate for 7.4.1.
> IMHO ZSTD compression is not a backport candidate because it is a new
feature. Moreover, substantial changes were introduced to both the gis and
raster library, which are in no way a bugfix, disqualifying it for
backporting.
Emphasizing the backporting issue: backporting (in this case) is not
trivial because it involves several low-level changes. If you want to use
ZSTD compression, use trunk r71892. If you want more meaningful messages
about why (de-)compression fails, use trunk r72042.
Equivalent for any other new features in trunk: use trunk with the
revision when this new feature was added.
Feedback to new features helps to keep trunk robust (suitable for everyday
work).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3499#comment:3>
