[GRASS-dev] [GRASS GIS] #3487: vector digitizer unstable
trac at osgeo.org
Sun Feb 25 07:33:40 PST 2018
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: wxGUI | Version: 7.2.2
Resolution: | Keywords: digitizer
CPU: OSX/Intel | Platform: MacOSX
Comment (by balagates):
I believe I am experiencing this same bug. I have a new build of Grass
7.4.0 using MacPorts. I am using macOS 10.12.6. I had similar problems
with Grass 7.2. I was able to use vdigit in Grass 7.0 but my OS and build
process were likely different.
The GUI crash always seems to happen (it is not intermittend for me) with
three different ways of launching vdigit. From the Layer Manager I have
tried 1) right clicking on vector and selecting "start editing", 2)
pressing the button "edit selected vector map". From the Grass display I
can successfully change the mode to "vector digitizer" which shows the
vdigit interface but when I select the vector from the pulldown I get the
crash.
I have various crash logs and they all seem similar. The "Performing
@selector(clickedAction:)" is slightly different based on which path I
took to cause the crash. Parts of one, through the Display window, are
pasted below.
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000ad
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0xad:
__TEXT 0000000103706000-0000000103708000 [ 8K]
r-x/rwx SM=COW
/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python
Application Specific Information:
Performing @selector(clickedAction:) from sender wxNSToolBarButton
0x7ff46c80f770
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 _ctypes.so 0x000000010b498628
PyObject_stgdict + 8
1 _ctypes.so 0x000000010b497360 ConvParam + 32
2 _ctypes.so 0x000000010b496ead
_ctypes_callproc + 205
3 _ctypes.so 0x000000010b4909cd PyCFuncPtr_call
+ 1101
4 org.python.python 0x000000010371dfe5 PyObject_Call +
101
5 org.python.python 0x00000001037c49c3
PyEval_EvalFrameEx + 21123
6 org.python.python 0x00000001037bf504
PyEval_EvalCodeEx + 2132
7 org.python.python 0x00000001037c86fd fast_function +
109
8 org.python.python 0x00000001037c4825
PyEval_EvalFrameEx + 20709
9 org.python.python 0x00000001037bf504
10 org.python.python 0x00000001037c86fd fast_function +
109
11 org.python.python 0x00000001037c4825
12 org.python.python 0x00000001037c87e3 fast_function +
339
13 org.python.python 0x00000001037c4825
14 org.python.python 0x00000001037c87e3 fast_function +
339
15 org.python.python 0x00000001037c4825
16 org.python.python 0x00000001037bf504
17 org.python.python 0x0000000103744b31 function_call +
337
18 org.python.python 0x000000010371dfe5 PyObject_Call +
101
19 org.python.python 0x000000010372bf02
instancemethod_call + 162
20 org.python.python 0x000000010371dfe5 PyObject_Call +
101
21 org.python.python 0x00000001037c80ff
PyEval_CallObjectWithKeywords + 159
22 _core_.so 0x000000010414d5a8
wxPyCallback::EventThunker(wxEvent&) + 504
23 libwx_baseu-3.0.dylib 0x0000000104cc2207
wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&,
wxEvtHandler*, wxEvent&) + 93
24 libwx_baseu-3.0.dylib 0x0000000104cc353f
wxEvtHandler::SearchDynamicEventTable(wxEvent&) + 89
25 libwx_baseu-3.0.dylib 0x0000000104cc3490
wxEvtHandler::TryHereOnly(wxEvent&) + 40
26 libwx_baseu-3.0.dylib 0x0000000104cc33d4
wxEvtHandler::ProcessEventLocally(wxEvent&) + 40
27 libwx_baseu-3.0.dylib 0x0000000104cc3367
wxEvtHandler::ProcessEvent(wxEvent&) + 185
28 libwx_baseu-3.0.dylib 0x0000000104cc35ab
wxEvtHandler::SafelyProcessEvent(wxEvent&) + 15
29 libwx_osx_cocoau_core-3.0.dylib 0x0000000104821259
wxToolBarBase::OnLeftClick(int, bool) + 79
30 libsystem_trace.dylib 0x00007fff9d04f3a7
_os_activity_initiate_impl + 53
31 com.apple.AppKit 0x00007fff854c7721
-[NSApplication(NSResponder) sendAction:to:from:] + 456
32 com.apple.AppKit 0x00007fff84fabcc4 -[NSControl
sendAction:to:] + 86
33 com.apple.AppKit 0x00007fff84fabbec __26-[NSCell
_sendActionFrom:]_block_invoke + 136
34 libsystem_trace.dylib 0x00007fff9d04f3a7
35 com.apple.AppKit 0x00007fff84fabb44 -[NSCell
_sendActionFrom:] + 128
36 com.apple.AppKit 0x00007fff84fee539 -[NSButtonCell
_sendActionFrom:] + 98
37 libsystem_trace.dylib 0x00007fff9d04f3a7
38 com.apple.AppKit 0x00007fff84faa426 -[NSCell
trackMouse:inRect:ofView:untilMouseUp:] + 2481
39 com.apple.AppKit 0x00007fff84fee272 -[NSButtonCell
trackMouse:inRect:ofView:untilMouseUp:] + 798
40 com.apple.AppKit 0x00007fff84fa8ddb -[NSControl
mouseDown:] + 832
41 com.apple.AppKit 0x00007fff8564324f
-[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 6341
42 com.apple.AppKit 0x00007fff8563fa6c
-[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 1942
43 com.apple.AppKit 0x00007fff8563ef0a
-[NSWindow(NSEventRouting) sendEvent:] + 541
44 libwx_osx_cocoau_core-3.0.dylib 0x0000000104742bcc -[wxNSWindow
sendEvent:] + 117
45 com.apple.AppKit 0x00007fff854c3681
-[NSApplication(NSEvent) sendEvent:] + 1145
46 libwx_osx_cocoau_core-3.0.dylib 0x00000001046a433e
-[wxNSApplication sendEvent:] + 98
47 com.apple.AppKit 0x00007fff84d3e427 -[NSApplication
run] + 1002
48 libwx_osx_cocoau_core-3.0.dylib 0x000000010473a1ec
wxGUIEventLoop::OSXDoRun() + 158
49 libwx_baseu-3.0.dylib 0x0000000104c9b3af
wxCFEventLoop::DoRun() + 39
50 libwx_baseu-3.0.dylib 0x0000000104bfeefd
wxEventLoopBase::Run() + 165
51 libwx_baseu-3.0.dylib 0x0000000104bd0cfa
wxAppConsoleBase::MainLoop() + 102
52 _core_.so 0x0000000104148954
wxPyApp::MainLoop() + 84
53 _core_.so 0x00000001041aa212
_wrap_PyApp_MainLoop(_object*, _object*) + 82
54 org.python.python 0x00000001037c04b0
PyEval_EvalFrameEx + 3440
55 org.python.python 0x00000001037bf504
56 org.python.python 0x0000000103744b31 function_call +
337
57 org.python.python 0x000000010371dfe5 PyObject_Call +
101
58 org.python.python 0x000000010372bf02
59 org.python.python 0x000000010371dfe5 PyObject_Call +
101
60 org.python.python 0x00000001037c49c3
61 org.python.python 0x00000001037c87e3 fast_function +
339
62 org.python.python 0x00000001037c4825
63 org.python.python 0x00000001037bf504
64 org.python.python 0x00000001037c86fd fast_function +
109
65 org.python.python 0x00000001037c4825
66 org.python.python 0x00000001037bf504
67 org.python.python 0x00000001037beca2 PyEval_EvalCode
+ 34
68 org.python.python 0x00000001037eac1d
PyRun_FileExFlags + 157
69 org.python.python 0x00000001037ea799
PyRun_SimpleFileExFlags + 697
70 org.python.python 0x000000010380080e Py_Main + 3006
71 libdyld.dylib 0x00007fff9ce1d235 start + 1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3487#comment:3>
