[GRASS-dev] [GRASS GIS] #3504: v.rast.stats: add "mode" and "diversity" to methods
trac at osgeo.org
Sun Feb 25 19:18:36 PST 2018
Reporter: veroandreo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.1
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.rast.stats
CPU: Unspecified | Platform: Unspecified
Comment (by veroandreo):
Replying to [comment:1 annakrat]:
> Not that it would probably help here, but there is r.mode module.
Yes, you are right. But using r.mode for this case does not make any
difference, it would be the same than using r.statistics. I need to query
a LC map with a polygon vector map and get the mode and diversity in the
attribute table of the vector map.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3504#comment:2>
