[GRASS-dev] [GRASS GIS] #789: g.region option to expand the computational region of about "some" pixels?
trac at osgeo.org
Tue Feb 27 11:22:03 PST 2018
Reporter: nikos | Owner: grass-dev@…
Type: | Status: closed
enhancement |
Priority: normal | Milestone: 7.4.1
Component: Default | Version: unspecified
Resolution: fixed | Keywords: g.region, expand computational
CPU: | region
Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
Should this be `g.region pixels=` or `cells=` or something else?
Pixel is not really used in GRASS overall, see search in the HTML doc
folder:
$ cd dist.../docs/html
$ grep -Irn cell | wc
1360 16896 162701
$ grep -Irn cells | wc
654 8520 79660
$ grep -Irn pixel | wc
200 3035 32650
$ grep -Irn pixels | wc
108 1169 9922
$ grep -Irn cell | grep -E "^i\." | wc
35 400 3083
$ grep -Irn pixel | grep -E "^i\." | wc
103 1115 11107
# (the singular search contains plural too)
Cell(s) seems to be much more common than pixel(s). And half of the pixel
matches seems to be in imagery modules (which is not the case for cell).
g.region manual page (G7:g.region) does not contain the word pixel and
neither does the raster intro page (G7:rasterintro). (In case of the intro
it should, but that's another story.)
Based on that it seems that `cells` should be used instead of `pixels` but
`cells` is in the g.region output telling us the total number of cell, so
perhaps that would be confusing and not enough descriptive. (Is it total
cells/pixels or something your are adding or removing?) Looking at the
keywords here, expand, extend, enlarge, increase, add, make_larger,
broaden, plus, and grow seems possible. My suggestion is:
enlarge=value
Number of cells to enlarge the bounding box
This does not account for the opposite case when a negative number is
provided (from the code I assume it works) but that can be implicit or
handled by a detailed description (using label and description).
Ticket URL: <https://trac.osgeo.org/grass/ticket/789#comment:31>
