[GRASS-dev] [GRASS GIS] #3505: Opening a workspace file
trac at osgeo.org
Wed Feb 28 12:27:51 PST 2018
Reporter: clerici | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.4.1
Component: wxGUI | Version: 7.4.0
Resolution: | Keywords: wingrass
CPU: Unspecified | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:5 martinl]:
> No traceback in Console?
set DEBUG=3 and then opened the workspace
C:\>D1/3: G_set_program_name(): g.gisenv
D3/3: G_option_to_separator(): key = separator -> sep = '
D1/3: grass.script.core.start_command(): g.tempfile -d pid=12544
D1/3: G_set_program_name(): g.tempfile
D2/3: G_file_name(): path = D:\grassdata\nc_spm_08_grass7\user1
D2/3: G__temp_element(): .tmp/unknown (tmp=0)
D:\grassdata\nc_spm_08_grass7\user1\.tmp/unknown\12544.0
D2/3: G_tempfile_pid():
D1/3: grass.script.core.start_command(): g.gisenv -n
D1/3: grass.script.core.start_command(): g.proj -p
D1/3: grass.script.core.start_command(): g.region -ugpc
D1/3: grass.script.core.start_command(): g.findfile -n mapset=user1
file=MASK element=cell
D1/3: G_set_program_name(): g.findfile
D2/3: G_file_name(): path = D:\grassdata\nc_spm_08_grass7\user1\cell\MASK
D1/3: grass.script.core.start_command(): g.region -ugpc s=215000.0
e=645000.0 w=630000.0 n=228500.0
D1/3: grass.script.core.start_command(): g.tempfile pid=12544
D:\grassdata\nc_spm_08_grass7\user1\.tmp/unknown\12544.1
D1/3: grass.script.core.start_command(): d.rast --q
map=elevation at PERMANENT
D1/3: grass.script.core.start_command(): d.vect --q color=blue
map=streams at PERMANENT fill_color=blue width=1
map=firestations at PERMANENT icon=extra/target width=1 size=1D5
D1/3: grass.script.core.start_command(): g.pnmcomp --o opacity=1.0,1.0,1.0
width=807
mask=c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmpya4dnk.pgm,c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmp8ucbs7.pgm,c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmphud9ld.pgm
height=501 bgcolor=255:255:255
input=c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmpya4dnk.ppm,c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmp8ucbs7.ppm,c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmphud9ld.ppm
output=D:\grassdata\nc_spm_08_grass7\user1\.tmp/unknown\12544.0.ppm
width=807
width=807
no other debug or traceback
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:7>
