[GRASS-dev] [GRASS GIS] #3332: v.proj - Error in pj_do_transform
trac at osgeo.org
Thu Jan 4 14:28:34 PST 2018
Reporter: DmitryKolesov | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Projections/Datums | Version: 7.2.2
Resolution: | Keywords: v.proj
CPU: Unspecified | Platform: Unspecified
Changes (by neteler):
* keywords: => v.proj
* version: unspecified => 7.2.2
* component: Default => Projections/Datums
* milestone: 7.2.3 => 7.4.0
Comment:
Potentially good news: I have reproduced your perfectly reported test case
and it works in GRASS GIS 7.4.svn (to become 7.4.0):
# last step of test case:
GRASS 7.4.0svn (TEST):~/tmp > v.proj location=TEST in=test
Reprojecting primitives ...
Building topology for vector map <test at PERMANENT>...
Registering primitives...
3 primitives registered
3 vertices registered
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
100%
Number of nodes: 0
Number of primitives: 3
Number of points: 3
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
GRASS 7.4.0svn (TEST):~/tmp > v.info test -e
name=test
mapset=PERMANENT
location=E4326
database=/home/mneteler/tmp
title=
scale=1:1
creator=mneteler
organization=
source_date=Thu Jan 4 23:19:53 2018
timestamp=none
format=native
level=2
num_dblinks=1
attribute_layer_number=1
attribute_layer_name=OGRGeoJSON
attribute_database=/home/mneteler/tmp/E4326/PERMANENT/sqlite/sqlite.db
attribute_database_driver=sqlite
attribute_table=test
attribute_primary_key=cat
projection=Latitude-Longitude
digitization_threshold=0.000000
comment=
It finally looks as expected.
Could you please try with 7.4.0RC1 or, even better, the weekly source code
snapshot [1] (or SVN branch)?
[1] https://grass.osgeo.org/grass74/source/snapshot/
Ticket URL: <https://trac.osgeo.org/grass/ticket/3332#comment:5>
