[GRASS-dev] GRASS GIS compilation on windows: SET OSGEO4W_ROOT=@osgeo4w@ not replaced by SET OSGEO4W_ROOT=C:\OSGeo4W64
Helmut Kudrnovsky hellik at web.de
Sat Jan 6 12:27:59 PST 2018
hi,
just tested compiling GRASS on windows; compilation works fine with the
instruction in:
https://trac.osgeo.org/grass/wiki/CompileOnWindows
but I've found in one of the last steps of installing following issue:
grass75svn.bat is copied to
C:\OSGeo4W64\bin\grass75svn.bat
the content is:
@echo off
rem
rem #
rem # GRASS initialization bat script (OSGeo4W)
rem #
rem
SET OSGEO4W_ROOT=@osgeo4w@ <=
comparing it with a OSGeo4W-installation:
@echo off
rem
rem #
rem #
rem
it seems @osgeo4w@  isn't replaced by C:\OSGeo4W64
any idea how to fix this?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
