[GRASS-dev] GRASS GIS compilation on windows: SET OSGEO4W_ROOT=@osgeo4w@ not replaced by SET OSGEO4W_ROOT=C:\OSGeo4W64
Helmut Kudrnovsky
hellik at web.de
Sat Jan 6 13:16:56 PST 2018
>the process is dedicated for creating osgeo4w package.
ok
>Anyway, created package must contain original bat file.
ok
>we could fix the local installation process (after the osgeo package
>is created).
if it's possible, yes.
otherwise we have to extend the wiki section.
https://trac.osgeo.org/grass/wiki/CompileOnWindows#Usage
Usage
To start GRASS use the icon on the desktop or if you want to be able to use
the command line from within GRASS.
Type in the OSGeo4W cmd console (assuming that we compiled GRASS 7.1):
c:\osgeo4w\bin\grass71svn.bat
that for a local use, SET OSGEO4W_ROOT= has to be set manually.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
