[GRASS-dev] [GRASS GIS] #2764: corrupt data written to FCELL and DCELL rasters, hard to re-produce
trac at osgeo.org
Tue Jan 9 14:29:37 PST 2018
Reporter: dylan | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Raster | Version: unspecified
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by dylan):
Replying to [comment:32 mmetz]:
> Markus Neteler in particular spent a lot of time to fix various systems
for parallel execution of GRASS commands. GRASS itself was never the
problem, instead the main problem was that the multiple outputs to be
written to a single storage device were too much for that storage device.
OK. Good to know. Are there any other diagnostics for these kind of
problems, other than looking through the output from `dmesg` or kernel
messages? I typically run `dstat` while developing parallel processing
scripts, but I haven't noticed any disk-thrashing in this case. I see that
the SSD is at about 5% of its "write bandwidth" as reported by `dstat`.
Each instance of `r.sun` is writing out ~5000 rows of data over a period
of about 8 minutes, so that is 5000 rows * 8 processes * 1/8 proc per
minute * 1/60 minutes per second = ~80 write operations per second
(assuming rows are written as processed). Are rows written 1-by-1, or in
batches?
> > I know this is a lot to ask, but did you try testing using ZLIB
compression and running it multiple times? It took a couple of tiles
before I noticed the error.
> I did use ZLIB compression when running the test with the data and
scripts provided. Do you mean I should run the test several times with the
same data?
Yes (please). It wasn't until I had ran a couple of tiles that I
encountered errors.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2764#comment:33>
