[GRASS-dev] [GRASS GIS] #2755: Commandline switch "/S" is not working anymore
GRASS GIS trac at osgeo.org
Wed Jan 10 03:46:03 PST 2018
  Reporter:  derseppel     |      Owner:  grass-dev@…
      Type:  defect        |     Status:  new
  Priority:  normal        |  Milestone:  7.0.6
 Component:  Installation  |    Version:  7.0.1
Resolution:                |   Keywords:  wingrass
       CPU:  Unspecified   |   Platform:  MSWindows 7
Comment (by aaronsmiley):
 Replying to [comment:27 sbl]:
 > Would it be an option for you to use the OSGeo4W command line
 installation:\\
 > https://trac.osgeo.org/osgeo4w/wiki/CommandLine\\
 > That works nicely for me and you can choose which extra packages you
 like to install ++\\
 > Just a suggestion instead of bothering with an /S flag...
 Now that looks promising.  I will try that.  Thank you for the suggestion!
 Replying to [comment:25 hellik]:
 > Replying to [comment:24 aaronsmiley]:
 > >   Sorry you've been waiting so long for a fix, that must be
 frustrating.
 > keep in mind, the winGRASS installer was done in voluntary work.
 Of course!  I do believe I said thank you in comments above.  I just came
 here because I saw /S wasn't silent and was hoping for a bug fix.  It's
 clear that this will not be fixed.
 Thank you again for your contributions regardless.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2755#comment:28>
