[GRASS-dev] [GRASS GIS] #3462: Allow setting environment variables in grass startup script
trac at osgeo.org
Thu Jan 11 15:26:07 PST 2018
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.3
Component: Startup | Version: 7.2.2
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by mankoff):
Hello again,
To try to clarify/summarize the above comments: OS X has a security
feature that makes `load_env()` not work properly, and therefore the
temporal framework is not available to OS X users. There is a simple work-
around: Remove one line in the startup script. Patch is attached.
There may be other ways to fix this bug, but I have not yet discovered
them, and the proposed fix is simple and has no downsides that I can see
or that anyone has mentioned in the comments.
I have asked but not received an explanation for why this line exists in
the startup script. The offending line blocks users from `export`'ing
environment variables in `~/.grass7/bashrc`. This decision confuses me -
GRASS is a power-user tool, and anyone setting environment variables there
presumably knows what they are doing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:15>
