[GRASS-dev] [GRASS GIS] #3478: g.extension does not work with bitbucket repo
GRASS GIS trac at osgeo.org
Mon Jan 15 14:33:08 PST 2018
 Reporter:  veroandreo   |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.4.1
Component:  Default      |    Version:  svn-trunk
 Keywords:  g.extension  |        CPU:  Unspecified
 Platform:  Linux        |
 Using G7:g.extension to install an addon from a bitbucket repo gives
 error. Here is the command and error:
 g.extension extension=t.rast.in.gpm
 url=https://bitbucket.org/lrntct/t.rast.in.gpm
 Fetching <http://t.rast.in.gpm> from
 <https://bitbucket.org/lrntct/t.rast.in.gpm/get/default.zip> (be
 patient)...
 ERROR: Extension <http://t.rast.in.gpm> not found
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478>
