[GRASS-dev] Grass on MacOS (Ken Mankoff)
Helena Mitasova hmitaso at ncsu.edu
Tue Jan 16 17:53:29 PST 2018
Michael,
thank you for the dmg file - great news - I was able to get GRASS running on my new laptop in less than 10 minutes including download. On first double click it refused to open that it is not verfied but it allowed me to open it by clicking on it and selecting Open in the menu ( I remebered that trick from the past).
I noticed that it does not have r.in.lidar (I am aware of the issue) but nviz and map swipe runs, g.gui.animation  has a problem. Anyway it is fantastic to have GRASS Mac binary back - thank you all for the effort,
Helena
On Jan 16, 2018, at 6:08 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> Hi Eric,
> I just started from scratch and compiled GRASS under Anaconda, created an app, and created a dmg. It runs with a double click. This is great!! Tonight, I will test on my laptop at home with SIP turned on. Fingers crossed.
> Cheers
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton <http://www.public.asu.edu/~cmbarton>, http://csdc.asu.edu <http://csdc.asu.edu/>
>> On Jan 15, 2018, at 10:22 PM, Eric Hutton <hutton.eric at gmail.com <mailto:hutton.eric at gmail.com>> wrote:
>> Hi Michael
>> That's great!
>> I included those two extra shell scripts as they were used with a previous version of grass. They are called in the Grass.sh script. I don't really know what they do, maybe they are no longer necessary.
>> To be honest, I'm not sure how I got the size down so much. After installing grass into the app, I ran "conda clean --all" and manually removed everything under the Contents/Resources/pkgs folder - but that's what I had always been doing (I think, anyway).
>> I've added the updated scripts to the GitHub repo. I think that now has everything I was working with created the app that's now working for you.
>> Eric
>> On Mon, Jan 15, 2018 at 9:35 PM Michael Barton <Michael.Barton at asu.edu <mailto:Michael.Barton at asu.edu>> wrote:
>> Eric,
>> I wrote you on this but apparently it never was sent.
>> I tested your new app and it works like a charm. Opens with a double click and no problems. There are a couple extra shell scripts in ../Contents/MacOS/ that don't seem to be called by anything. Or am I just not seeing it? I will try inserting the new start up scripts into my own build tomorrow and see if it works the same.
>> How did you get the size down so much? I got it close last week by removing the pkg folder, env folder, doc folder, and then some selective items in bin. But I'm hoping your have a more systematic list of what can be removed.
>> This looks like exactly what is needed. Hopefully I can package it as you did and get it posted to test by the end of the week.
>> Thanks again
>> Michael
>> C. Michael Barton
>> voice:  480-965-6262 <tel:(480)%20965-6262> (SHESC), 480-965-8130 <tel:(480)%20965-8130>/727-9746 (CSDC)
>> fax: 480-965-7671 <tel:(480)%20965-7671> (SHESC),  480-727-0709 <tel:(480)%20727-0709> (CSDC)
>> www: http://www.public.asu.edu/~cmbarton <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=bZO0cwfnfukYmqi5yUY-XWAS-FM82fSNuA5sgMVg_6k&s=d-wHxIaPaQdDW6cxn3R8zKtBvdihUlHng4s9IUsNqmI&e=>, http://csdc.asu.edu <https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=bZO0cwfnfukYmqi5yUY-XWAS-FM82fSNuA5sgMVg_6k&s=bXpN34ZGq_LF97BNf4YUyBxSRKXyz_I7U6DU5FHU27I&e=>
>>> On Jan 14, 2018, at 3:23 PM, Eric Hutton <hutton.eric at gmail.com <mailto:hutton.eric at gmail.com>> wrote:
>>> Hi Michael
>>> Thanks for your earlier clarification about how grass runs (I was missing a key point!). I think I have a solution now. Basically, the Grass72.app/Contents/MacOS/Grass script now opens up a terminal and, within that terminal, executes the startup script (the one we were using before, which is now Grass.sh).
>>> You can see what I mean here:
>>>     https://github.com/mcflugen/grass-conda-build/tree/master/osx/Grass72.app/Contents/MacOS <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_mcflugen_grass-2Dconda-2Dbuild_tree_master_osx_Grass72.app_Contents_MacOS&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=XA6yReZT2BoAaNeg126zooD8EtmwRkQ-7rwLzxODg7I&s=QrgVzZR0j3uDdl8IY0RGC58H9UUyvn6xgvsVYTYozm8&e=>
>>> I'll start to make a new app but the one I have seems to be working now (I've been using the NC data you sent me).
>>> Eric
>>> On Sun, Jan 14, 2018 at 1:31 PM Michael Barton <Michael.Barton at asu.edu <mailto:Michael.Barton at asu.edu>> wrote:
>>> Ken & Co.
>>> You might find this of interest.
>>> I've been working off and on for the past several month to find a new way to compile and distribute GRASS for Mac with all dependencies created outside the Mac system folders and bundled with it. The goal is to eliminate the SIP problem and the potential for conflicts with different versions of dependencies/frameworks/python/wxpython.
>>> With a lot of help from colleague Eric Hutton (Community Surface Dynamics Modeling System), we are very close to having a reproducible and distributable build of GRASS under Anaconda. Our goal is to compile GRASS in an Anaconda environment so that it is distributable in two related ways: as a standard Mac package and app, and as an Anaconda package (installed via the command 'conda install [grass version]'). This will be a fully 64 bit GRASS version using wxPython 3 for the GUI.
>>> Due to the many other responsibilities and pulls on our time, Eric and I have only been able to work sporadically. But as of this week we are down to one main baffling and annoying problem left to solve. Then we can do some clean up and begin making this build available to test. With that in mind, if anyone has experience in creating Mac *.app and *.pkg environments for distribution, please get in touch. You might be able to help us get over the last hurdle.
>>> Cheers
>>> Michael
>>> C. Michael Barton
>>> www: http://www.public.asu.edu/~cmbarton <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=XA6yReZT2BoAaNeg126zooD8EtmwRkQ-7rwLzxODg7I&s=f-Q3ncZP4puDJcsGLhZyfCTIs1uS9BGyr6DLDgdSRLc&e=>, http://csdc.asu.edu <https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=XA6yReZT2BoAaNeg126zooD8EtmwRkQ-7rwLzxODg7I&s=kNcCR_LAcIYMBOEXCrReotFe6ZkwH1z-cVfgpGNQ2KU&e=>
>>>> On Jan 14, 2018, at 1:00 PM, grass-user-request at lists.osgeo.org <mailto:grass-user-request at lists.osgeo.org> wrote:
>>>> From: Ken Mankoff <mankoff at gmail.com <mailto:mankoff at gmail.com>>
>>>> Subject: Re: [GRASS-user] Grass on MacOS
>>>> Date: January 14, 2018 at 7:46:27 AM MST
>>>> To: Adam Dershowitz <adershowitz at exponent.com <mailto:adershowitz at exponent.com>>
>>>> Cc: Carlos Grohmann <carlos.grohmann at gmail.com <mailto:carlos.grohmann at gmail.com>>, "grass-user\@lists.osgeo.org <https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=XA6yReZT2BoAaNeg126zooD8EtmwRkQ-7rwLzxODg7I&s=yZDoUcNj1d74AFJRYotWx_ewnwtaFx97LQBYr0ErH_s&e=>" <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>>
>>>> Hi Adam,
>>>> I'm glad to hear you got GRASS working on OS X w/ MacPorts. That is the system I use too. I recently switched from HomeBrew. I got GRASS working with fink too, but prefer MacPorts, although there are some MacPort-specific issues if you want to use the temporal framework.
>>>> I found it helpful to set GRASS_PYTHON and have it pointing to
>>>> export GRASS_PYTHON=/opt/local/bin/python2.7
>>>> I don't like installing 3rd-party frameworks, so I also have QGIS installed via MacPorts and it works well.
>>>> For GRASS, I had to "sudo port install gdal +netcdf" in order to be able to read in NetCDF files. For QGIS I did "sudo port install QGIS +qt4 +grass".
>>>>  -k.
>>>> On 2018-01-14 at 00:37, Adam Dershowitz <adershowitz at exponent.com <mailto:adershowitz at exponent.com>> wrote:
>>>>> Thanks, but…I use Macports for a bunch of things, and homebrew and
>>>>> maports don’t play well together. So, I can’t easily do that. I did
>>>>> get the macports version to work after I asked the question. It was
>>>>> actually just due to the fact that I have been using the Kyngchoas
>>>>> version for a long time, and that used to require that GRASS_PYTHON be
>>>>> set in .bash_profile. But, I had set it to point to an old directory a
>>>>> while back, and that folder didn’t exist. So, I just had to delete
>>>>> that environmental variable and the macports version now works fine.
>>>>> And, the Kyngchaos version of qgis does seem to work fine.
>>>>> Thanks for the suggestion. I suppose that it would be useful to have
>>>>> working binaries to avoid these kinds of issues.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Helena Mitasova
Professor at the Department of Marine,
Earth, and Atmospheric Sciences
Associate director and faculty fellow at the Center for Geospatial Analytics
North Carolina State University
Raleigh, NC 27695-8208
hmitaso at ncsu.edu
http://geospatial.ncsu.edu/osgeorel/publications.html <http://geospatial.ncsu.edu/osgeorel/publications.html>
"All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180116/43601c8a/attachment-0001.html>
