[GRASS-dev] [GRASS GIS] #3481: m.cogo (and others most likely) fail in Grass 7 under OS X if output path contains spaces
trac at osgeo.org
Sun Jan 21 12:01:33 PST 2018
contains spaces
Reporter: fgfletcher | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.0
Keywords: path quoting, m.cogo | CPU: OSX/Intel
Platform: MacOSX |
Occurs here under Mac OSX 10.12.6 when using GRASS 7 as bundled into QGIS
2.18.15-3.
m.cogo, and most likely others, fail under OS X if the output path
contains spaces. Input path seems unaffected.
So trying to send output into ~/my files/test_data/ results in an error
message that files/test_data is not legit.
OS X allows spaces (and other non-alphanumeric chars) within directory
(folder) or file names.
Consequently in OSX paths need to be "quoted" for Unix compatibility; I
suspect that is what is missing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3481>
